14 years agoJTAG error only when programming
Hello, I have a custom board with a MAXII CPLD (EPM2210F256), with the JTAG port built per the Handbook. With Quartus-II v. 9.1 and a ByteblasterMV cable I can ID the device, erase it, and bla...
14 years ago --- Quote Start --- I put an oscilloscope on the (4) JTAG signals and the power supply- all look very clean. --- Quote End --- What bandwidth is your scope? A low bandwidth ~50MHz scope might not show ringing and steps in the TCK signal due to transmission line reflections. --- Quote Start --- Can anyone shed any light on this or suggest other ideas to check? --- Quote End --- Try another ByteBlaster, or better yet, try a USB-Blaster. If you don't have one, Terasic sells them for $50. They work well. Cheers, Dave
