14 years agoJTAG error only when programming
Hello, I have a custom board with a MAXII CPLD (EPM2210F256), with the JTAG port built per the Handbook. With Quartus-II v. 9.1 and a ByteblasterMV cable I can ID the device, erase it, and bla...
14 years ago --- Quote Start --- My scope is 200MHz BW, 1Gsa/sec. If there are any glitches they are <10nsec wide and die out very fast. --- Quote End --- Ok, the scope sounds good enough. The fact that you do not see any glitches is a good sign. --- Quote Start --- Probably I will try the Terasic programmer (note Atlera lists their USB-Blaster for $300!). Also in proces of downloading the latest Quartus SW, so we'll see... --- Quote End --- Yeah, the Altera versions are way too pricey. The Terasic versions work great! Cheers, Dave
