gyuunyuu's avatar
gyuunyuu
6 years ago
Is there a standard way to store and retrieve "build information" of an FPGA design?
The following things are to be stored inside the FPGA:
1. Build date
2. Build time
3. Build top level file name
4. Build repository commit number for version controlled design
5. Submodule repository commit number for version controlled design
Is there a standard way to store and retrieve this information? The simplest method would be to somehow use JTAG to read them out.
  • ​I have 2 questions
    1. qsys-generate is an executable and not a tcl command. What is the preferred way of executing the qsys generation from tcl script (in contrast to command line shell script)?
    2. Is Quartus supposed to automatically regenerate the Qsys system for which it has a .qip file when we compile design, or it is the sole responsibility of the user to do this manually?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    You may execute the TCL script (let say first.tcl) that is use to update the HDL file of the custom Qsys component before synthesis by adding the command in the .qsf.
    set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:first.tcl
    For further information, you may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-scripting.pdf (Chapter 1.9 Automating Script Execution)
    You can either add the qsys-generate command in the first.tcl and add the above command in the .qsf file
    or
    create a .tcl that list all the execution flow in sequence and run the tcl.
    Please let me know if you have any questions.
  • OK, I will ask an alternate question. I have tcl script that can execute and generate those values into a HDL file just before synthesis takes place. I just want ​to know what command has to be run from tcl to cause the Qsys system to generate again. If I am using shell , I can use the "qsys-generate".
    What if I want to update the HDL file of a custom Qsys component via a tcl script, just before synthesis and then cause the Qsys system to regenerate just before synthesis starts? The "qsys-generate" can be run from shell but what do I need to use from the tcl script?
  • Hi gyuunyuu,
    We are sorry to tell you that we do not have the information to support your request. But for the record, we will raised this issue to our internal team for future support. We apologize for any inconveniences that come from us. Appreciate much for your understanding.
    Aim
  • ​Sorry, by build I meant the date and time of when the project was compiled. The item 3 is the ASCII name of the top level entity. The items 4 and 5 are related with Git based revision control system where we have hash number for the where we are on a branch in a repository.
    Since customers would like to do this quite often, I would expect that Intel/Altera has created a method to achieve this which is supported by them?
  • Hi gyuunyuu,
    For your information, 1. Build date, 2. Build time, can be obtained from the device itself. Please see the link below for the format,
    https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/decoder.html
    Moreover, please clarify more about number 3, 4, 5 in order for us to help you with the queries.
    Additionally, JTAG can only read device OPN and Chip Unit ID.
    Aim
