gyuunyuu
Contributor
6 years agoIs there a standard way to store and retrieve "build information" of an FPGA design?
The following things are to be stored inside the FPGA: 1. Build date 2. Build time 3. Build top level file name 4. Build repository commit number for version controlled design 5. Submodule repos...
KhaiChein_Y_Intel
6 years agoHi,
You may execute the TCL script (let say first.tcl) that is use to update the HDL file of the custom Qsys component before synthesis by adding the command in the .qsf.
set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:first.tcl
For further information, you may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-scripting.pdf (Chapter 1.9 Automating Script Execution)
You can either add the qsys-generate command in the first.tcl and add the above command in the .qsf file
or
create a .tcl that list all the execution flow in sequence and run the tcl.
Please let me know if you have any questions.
