grspbr's avatar
grspbr
4 years ago
ipgenerate does not generate SPD files - repost
@ShengN_Intel, I'm reposting this because I am no longer getting a response ... (For some reason I was not automatically subscribed - not getting notifications - to my own post which would be normal in any other forum.)
Here is the old post: https://community.intel.com/t5/Programmable-Devices/ipgenerate-does-not-generate-SPD-files/m-p/1393152#M85470
Please see the attached console output from our Jenkins build. I tried your command lines and still have a problem.
Original message follows:
I’ve been working on scripting the batch simulation of our project for quite a few days now and I cannot find a way to generate SPD files when I run the ipgenerate command. I’ve searched extensively and cannot find a solution from any user, on intel’s community or elsewhere. (The SPD files contain a list of files for simulation.)
I’m using these commands but the second command fails indicating that the SPD files do not exist – otherwise all the other files appear to be generated:
  • quartus_ipgenerate mcd4 --rev top --generate_project_ip_files --simulation=verilog --clear_ip_generation_dirs
  • /INTELFPGA_PRO_21.2/qsys/bin/ip-setup-simulation --quartus-project=mcd4 --simulator=RIVIERA
This is working when I do it manually from the Quartus GUI – i.e. generate IP, then generate the simulation setup files for RIVIERA.
  • Hi @grspbr,
    I don't think the problem is due to SPD are not generated. The SPD file is generated with quartus_ipgenerate command. Please find the attached file. You should see a common SPD file is generated for the whole qsys system called generic_flash_access in generic_flash_access folder and the device family is Agilex. However ip-setup-simulation command still fails (Error: No spd files are included in quartus project) even there is SPD file there. So this indicates Platform Designer folder structure of Agilex isn't supported for ip-setup-simulation as mentioned in KDB https://www.intel.com/content/www/us/en/support/programmable/articles/000086513.html. I think you can target that SPD file of the whole system to generate the setup script using ip-make-simscript command.
    Sheng
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
  • ShengN_altera's avatar
    ShengN_altera
    Hi @grspbr,
    Sheng
    • grspbr's avatar
      grspbr
      Hi @ShengN_Intel
      Right you are! I'm surprised I didn't check that with the "find" but you are correct that the files do exist. I'll use the ip-make-simscript command. Thank you for your help!
      Greg
  • KennyT_altera's avatar
    KennyT_altera
    Thanks for using Intel community forum,
    Kindly expect some delay in the reply due to holiday.
    ShengN_altera
    I found out the reason for causing this issue. Check this previous KDB link https://www.intel.com/content/www/us/en/support/programmable/articles/000086513.html I notice you're using Agilex device family right? As for that you have to use ip-make-simscript command:
    ip-make-simscript --spd=<ipA.spd,ipB.spd> --output-directory=<directory> --simulator=<simulator> (Specify one or more .spd files)
    ip-make-simscript --system-files=<ipA.ip, ipB.ip> --output-directory=<directory> --simulator=<simulator> (Specify one or more .ip files)
    ip-setup-simulation command isn't supported for Agilex device family.
    Sheng
    • grspbr's avatar
      grspbr
      Hi @ShengN_Intel
      Thank you for your reply. I saw this command and was surprised and concerned. It seems I have to tediously identify every single IP file we are using, about 200 of them. Is this true? There's no way for Quartus to do this automatically like previously? It's still one click with the GUI even with Agilex.
      Also, this command appears to require SPD files as input. However, this is the problem, that SPD are not generated in the first place.
      (Can you tell me why I am not receiving notifications of your replies? I checked my junk mail and see no replies there either.)
      Greg
