ipgenerate does not generate SPD files - repost
- 4 years ago
Hi @grspbr,
I don't think the problem is due to SPD are not generated. The SPD file is generated with quartus_ipgenerate command. Please find the attached file. You should see a common SPD file is generated for the whole qsys system called generic_flash_access in generic_flash_access folder and the device family is Agilex. However ip-setup-simulation command still fails (Error: No spd files are included in quartus project) even there is SPD file there. So this indicates Platform Designer folder structure of Agilex isn't supported for ip-setup-simulation as mentioned in KDB https://www.intel.com/content/www/us/en/support/programmable/articles/000086513.html. I think you can target that SPD file of the whole system to generate the setup script using ip-make-simscript command.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
