18 years ago
Implementing an accumulator and data recovery system
I'm struggling to implement an accumulator or an equivalent system using VHDL. I require it as part of my receiver design at add 26 bits and tell me whether the result was positive of negative. my processes use signed 2's complement representation. here is the code that i have made thus far.
--23/10/08 Accumulator design
--this block is supposed to add all the bits coming into the input
--and then send the output to the decision device
--quartus does not recognise the "+" operator:confused:?????
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
use ieee.numeric_bit.all;
entity accum is
port(clk : in std_logic;
data_in : in std_logic_vector (25 downto 0);
ready : in std_logic;
trigger : out std_logic;
data_out : out std_logic_vector (4 downto 0)--5 bit ouput
end accum;
architecture dt1 of accum is
begin
process(clk)
variable temp : std_logic_vector (25 downto 0);
begin
if rising_edge(clk) then
if ready='1' then
temp:= data_in;
data_out <= (temp(0) + temp(1) + temp(2) + temp(3) + temp(4) + temp(5)
+ temp(6) + temp(7) + temp(8) + temp(9) + temp(10) + temp(11)
+ temp(12) + temp(13) + temp(14) + temp(15) + temp(16) + temp(17)
+ temp(18) + temp(19) + temp(20) + temp(21) + temp(22) + temp(23)+
temp(24) + temp(25)); --adding all the parallel data
trigger<='1';
else trigger <='0';
end if;
end if;
end process;
end dt1;
Below is a decription of the recovery scheme i'm trying to implement
data at the receiver arrives as 14 signed bits then its multiplied by 2-bit walsh code resulting in 16-bits, this result is multiplied by 10-bit wavelet, the result is then sent at a summer and decision device
--received data (14-bits)--->(x)walsh code(2-bits)------>(x)wavelet(10-bits)------->Accumulator(sum of elements)------->Decision device----->recovered data(binary)
    try this process(I didn't test the code, expect some syntax issues)
    signal count : integer range 0 to 9;
    process(reset,r_clk) -- add reset to your module
    begin
    if reset='1' then
    count <= 0;
    trigger <= '0';
    r_data <= (others => '0');
    elsif rising_edge(r_clk) then
    if(ready = '1')then
    r_data<=rom(count);
    if(count = 9)then
    count <= 0;
    trigger <= '1';
    else
    count <= count + 1;
    trigger <= '0';
    end if;
    end if;
    end if;
    end process;
    counter <= count; -- or move this up if you need addr/data together
    hi there,
    i'm trying to implement a ROM in software using the code below, it works but i get some phanton data between the actual data that i am sending out when i simulate it using the waveform editor.
    --11/10/08 Second vesion of the rom, this time using the clock to directly cycle out the data
    --this version will not use the case statement, but use an if loop, a counter to cycle out the data at a
    --particular frequency.
    --based on code obtained form a help site http://www.edaboard.com/forum75.html
    --and wikivesity, an article on Computer Architecture Lab/HOWTO visited 27/09/08
    --21/10/08 Version two changed to add a ready signal
    --24/10/08--edited to add a trigger line and to add ready to the sensitivity list
    --29th/10/08--edited to ensure the last rom position is sent out. to do this i increased the count value
    library ieee;
    entity prbs is
    port(r_clk : in std_logic;--clock input at the user data frequency
    ready : in std_logic;--ready signal from sync
    r_data : out std_logic_vector (9 downto 0);--wavelet data vector representing a portion of the wavelet
    counter : out integer
    end prbs;
    architecture prbs of prbs is
    type mem is array (0 TO 9) of std_logic_vector (9 downto 0);
    constant rom : mem :=(
    0 => "0000000100",
    1 => "0000000111",
    2 => "1111101011",
    3 => "0000011100",
    4 => "1110110100",
    5 => "1111101011",
    6 => "0011000011",
    7 => "1110110100",
    8 => "1110011000",
    9 => "0000111011"
    begin
    process(ready,r_clk)
    variable count : integer :=0;--defining a counter
    begin
    if ready='1' then
    if rising_edge(r_clk) then--i'm not sure whether the program will return here after sending out the data!
    r_data<=rom(count);
    counter<=count;
    count:=count+1;
    if count=11 then --check whether the ROM addresses have been exceeded
    count:=0;
    trigger<='1';--trigger next module
    else trigger<='0';
    end if;
    end if;
    end if;
    end process;
    end prbs;
    Hi Zadok
    For addition I suggest that you convert a single bit to unsigned bus(one bit or if Quartus not happy two bits) then add all your data. However, your adder chain is very long and you are likely to have timing problem. If so, consider pipelining.
    Kaz
