18 years agoImplementing an accumulator and data recovery system
Hi, I'm struggling to implement an accumulator or an equivalent system using VHDL. I require it as part of my receiver design at add 26 bits and tell me whether the result was positive of negat...
17 years agohi there,
i'm trying to implement a ROM in software using the code below, it works but i get some phanton data between the actual data that i am sending out when i simulate it using the waveform editor. --11/10/08 Second vesion of the rom, this time using the clock to directly cycle out the data --this version will not use the case statement, but use an if loop, a counter to cycle out the data at a --particular frequency. --based on code obtained form a help site http://www.edaboard.com/forum75.html --and wikivesity, an article on Computer Architecture Lab/HOWTO visited 27/09/08 --21/10/08 Version two changed to add a ready signal --24/10/08--edited to add a trigger line and to add ready to the sensitivity list --29th/10/08--edited to ensure the last rom position is sent out. to do this i increased the count value library ieee; use ieee.std_logic_1164.all; entity prbs is port(r_clk : in std_logic;--clock input at the user data frequency ready : in std_logic;--ready signal from sync trigger : out std_logic; r_data : out std_logic_vector (9 downto 0);--wavelet data vector representing a portion of the wavelet counter : out integer ); end prbs; architecture prbs of prbs is type mem is array (0 TO 9) of std_logic_vector (9 downto 0); constant rom : mem :=( 0 => "0000000100", 1 => "0000000111", 2 => "1111101011", 3 => "0000011100", 4 => "1110110100", 5 => "1111101011", 6 => "0011000011", 7 => "1110110100", 8 => "1110011000", 9 => "0000111011" ); begin process(ready,r_clk) variable count : integer :=0;--defining a counter begin if ready='1' then if rising_edge(r_clk) then--i'm not sure whether the program will return here after sending out the data! r_data<=rom(count); counter<=count; count:=count+1; if count=11 then --check whether the ROM addresses have been exceeded count:=0; trigger<='1';--trigger next module else trigger<='0'; end if; end if; end if; end process; end prbs;
