sbj's avatar
sbj
1 day ago
HPS DDR Interface
For the HPS memory controller (DDR interface):
  • Is it possible to swap DQS differential pairs (P/N inversion) through software or configuration?
  • Or must signal polarity strictly be respected at the PCB level?
1 Reply
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    You are able to do the swapping of a Differential pairs in the device through some RTL logic before the HPS EMIF IP Core.
    However there is no option in the IP to do this.
    https://community.altera.com/kb/knowledge-base/can-i-swap-the-positive-p-and-negative-n-signals-of-a-differential-pair/340214
    tehjingy
