How to use up all cells in an FPGA?
I am going to be doing some radiation testing on an MAXII FPGA and I would like to program it with a fairly simple program that tells me when the FPGA has an upset. I would like the program to exercise most or all of the cells in the FPGA so that I can say whether or not the FPGA passed the testing with resonable certainty. I am not quite sure of a way to have a simple program use most of the space in an FPGA so I wanted to see if anyone had any input?? It would be much appreciated!!!
GR2 Replies
LFSR will do and another possible simple filler code is running several counters together then testing their equality.
type my_array is array(1 to 10) of integer range(0 to 255); signal counter: my_array; signal flag : std_logic_vector(9 downto 1); ...... process(reset,clk) begin if reset = '1' then counter <= (others => 0); flag <= (others => '0'); elsif rising_edge(clk) then for i in 1 to 10 loop counter(i) <= counter(i) + 1; end loop; for i in 1 to 9 loop if counter(i) = counter(i+1) then flag(i) <= '0'; else flag(i) <= '1'; end if; end loop; end if; end process; alarm <= '1' when flag /= "000000000" else '0';--may need latching - Altera_Forum
MAX II has non-volatile (flash) configuration storage. Corruption of configuration memory would be the most likely radiation effect, but can be easily detected by a verify.
Regarding the suggested test, even if all logic elements are utilized in a design, the routing resources can't. So you can't achieve a 100% test anyway. Statistical considerations suggest however, that the significance of your test doesn't change much if you have 95% or 100% utilisation. Thus you should rather think about a test design that allows easy and complete verification of it's results rather than 100% utilisation. Two identical LFSR with a comparison of both outputs can be starting point. You can add some arbitrary operations on the output numbers to fill up the logic array.
