13 years ago
how to use another vhdl file's function?
bin2bcd7 is not in the scope
and
error at H1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0);
bin2bcd7.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity bin2bcd7 is
Port ( bin_in : in STD_LOGIC_VECTOR (3 downto 0);
bcd7_out : out STD_LOGIC_VECTOR (6 downto 0));
end bin2bcd7;
architecture Behavioral of bin2bcd7 is
top file - Lab2.vhd
library IEEE;
entity Lab2 is
Port (
HEX0 : OUT STD_LOGIC_VECTOR(6 DOWNTO 0));
end Lab2;
architecture Behavioral of Lab2 is
begin
bin2bcd7(X"0001",HEX0);
end Behavioral;
or
library IEEE;
entity Lab2 is
Port (
end Lab2;
component bin2bcd7
port (bin_in : in STD_LOGIC;
end component;
begin
end Behavioral;
    Success, it really works, it can display one in 7 segment LED
    You will learn soon that "less error" doesn't always mean better ;)
    It should work without the 'X', but from what I see your component declaration in the architecture is wrong, you have defined bin_in and bcd7_out as std_logic signals instead of std_logic_vector.
    I don't see any mistake in the port map, so I don't get why you have this error. Is the coma there between the two port associations?
    And from the code in bin2bcd, the input port bin_in is 4 bits wide and not 4 hexadecimal digits wide, so in your portmap you should use "0001" and not X"0001"
    Error (10500): VHDL syntax error at Lab2.vhd(19) near text "=>"; expecting ")", or ","
    i just want to input "0001" into bin_in and output from bcd7_out to HEX0 to display a digit number on board
    bin2bcd7.vhd
    library IEEE;
    entity bin2bcd7 is
    end bin2bcd7;
    begin
    with bin_in Select
    bcd7_out<=
    "1111001"when"0001",
    "0100100"when"0010",
    "0110000"when"0011",
    "0011001"when"0100",
    "0010010"when"0101",
    "0000010"when"0110",
    "1111000"when"0111",
    "0000000"when"1000",
    "0010000"when"1001",
    "0001000"when"1010",
    "0000011"when"1011",
    "1000110"when"1100",
    "0100001"when"1101",
    "0000110"when"1110",
    "0001110"when"1111",
    "1000000"when others;
    end Behavioral;
    I didn't understand your problem or question, but I think this line
    should be
    H1:bin2bcd7 port map (bin_in => X"0001", bcd7_out => HEX0);
