13 years agohow to use another vhdl file's function?
bin2bcd7 is not in the scope and error at H1:bin2bcd7 port map (X"0001" => bin_in, bcd7_out => HEX0); bin2bcd7.vhd library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_...
13 years agoError (10500): VHDL syntax error at Lab2.vhd(19) near text "=>"; expecting ")", or ","
i just want to input "0001" into bin_in and output from bcd7_out to HEX0 to display a digit number on board bin2bcd7.vhd library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity bin2bcd7 is Port ( bin_in : in STD_LOGIC_VECTOR (3 downto 0); bcd7_out : out STD_LOGIC_VECTOR (6 downto 0)); end bin2bcd7; architecture Behavioral of bin2bcd7 is begin with bin_in Select bcd7_out<= "1111001"when"0001", "0100100"when"0010", "0110000"when"0011", "0011001"when"0100", "0010010"when"0101", "0000010"when"0110", "1111000"when"0111", "0000000"when"1000", "0010000"when"1001", "0001000"when"1010", "0000011"when"1011", "1000110"when"1100", "0100001"when"1101", "0000110"when"1110", "0001110"when"1111", "1000000"when others; end Behavioral;
