Yes, it's O.K. for AS programming, I've often used it.
but now it showing silicon id error.... the pof can not be downloaded into up3 even at jp11 and in AS mode!
What's the exact error message? Is it:
--- Quote Start --- Error: Can't recognize silicon ID for device 1 --- Quote End --- This normally indicates a hardware problem of the programming adapter or the configuration device. Revision 01 UP3 has an EPCS1 in a DIL socket. Is it mounted correctly at all? - Altera_Forum
yes, it is showing Error: Can't recognize silicon ID for device 1
i can find u15(epcs1) on my bottom board! but while in AS mode, the .pof was automatically set to epcs4... if change device to epsc1, the new .pof will be unknown, then will not be able to download! - Altera_Forum
The two problems are unrelated, I think. EPCS1 has to be selected in Quartus device options to generate the right *.pof file type. This must be done anyway.
"Can't recognize silicon ID" is another issue. As I said, I assume a hardware problem. With some boards, there may be special setup issues than can cause AS access failure, but I'm not aware with the UP3 board. - Altera_Forum
really a million thanks to FVM... luckyly u remind me that to chk the into the device option.... it really is the main problem there since it was set to auto at the device options. i have tried to set to epsc1 and it is working well now...
issue solved.... really thanks a lot, Fvm ! nice to meet u at here! - Altera_Forum
I'm glad that you finally solved it!
