mappy5's avatar
mappy5
4 years ago
how to set timing constraint for clock
In the case of the circuit shown in the figure, how should the timing constraint be set?
Do CLK_1 and CLK_2 need timing constraints?
create_clock -name {in_CLK} -period 20.0 [get_ports {in_CLK}]
create_generated_clock -name {CLK_half} -source [get_ports {in_CLK}] -divide_by 2 -master_clock {in_CLK} [get_nets{CLK_half}]
  • mappy5's avatar
    mappy5
    Is this the right way to set timing constraints on CLK_1?
    create_generated_clock -name CLK_1 -source [get_registers {yyy:xxx|half_1}] -divide by 245760 [get_registers {yyy:xxx|CLK_1}]
    • sstrell's avatar
      sstrell
      Yes, that's the idea, though like I said, you probably have to create a clock for half_1 as well.
  • sstrell's avatar
    sstrell
    Unconstrained clocks are reported based on them driving the clock inputs of registers or other clocked logic. Even super slow clocks should have timing constraints for completeness.
  • sstrell's avatar
    sstrell
    Yes, all clock domains need constraints.
    If you are using a PLL to create these clocks, you can simply use derive_pll_clocks. If you are not using a PLL, you will need additional generated clock constraints for clk_1 and clk_2 (and possibly that other clock that generates clk_1 and clk_2).
    See the unconstrained paths report in the timing analyzer to see which clocks are considered unconstrained, if any.
    • mappy5's avatar
      mappy5
      hi, Thank you for answering.
      PLL is not use.
      Generate the clock with the logic I created.
      clk_1 is 132Hz
      clk_2 is 339Hz
      Clk_1 and clk_2 were not pointed to unconstrained paths in the timing analyzer.
      Is there no timing constraints for such a low speed clock?
