mappy5
4 years agohow to set timing constraint for clock
In the case of the circuit shown in the figure, how should the timing constraint be set?
Do CLK_1 and CLK_2 need timing constraints?
create_clock -name {in_CLK} -period 20.0 [get_ports {in_CLK}]...
sstrell
4 years agoYes, all clock domains need constraints.
If you are using a PLL to create these clocks, you can simply use derive_pll_clocks. If you are not using a PLL, you will need additional generated clock constraints for clk_1 and clk_2 (and possibly that other clock that generates clk_1 and clk_2).
See the unconstrained paths report in the timing analyzer to see which clocks are considered unconstrained, if any.
mappy5
4 years agohi, Thank you for answering.
PLL is not use.
Generate the clock with the logic I created.
clk_1 is 132Hz
clk_2 is 339Hz
Clk_1 and clk_2 were not pointed to unconstrained paths in the timing analyzer.
Is there no timing constraints for such a low speed clock?
