mappy5
4 years agohow to set timing constraint for clock
In the case of the circuit shown in the figure, how should the timing constraint be set?
Do CLK_1 and CLK_2 need timing constraints?
create_clock -name {in_CLK} -period 20.0 [get_ports {in_CLK}]...
mappy5
4 years agoIs this the right way to set timing constraints on CLK_1?
create_generated_clock -name CLK_1 -source [get_registers {yyy:xxx|half_1}] -divide by 245760 [get_registers {yyy:xxx|CLK_1}]
sstrell
4 years agoYes, that's the idea, though like I said, you probably have to create a clock for half_1 as well.
