14 years ago
How to set multicycle for this design?
In my design, all clocks are clka (100 MHz), but clock enables are used to make registers change at 25 MHz or 6.25 MHz.
The signal path is reg1(clka,100MHz)->reg2(enable to 25 MHz, clocked by clka)->reg3(enable to 25MHz,clocked by clka)->reg4(Enable to 6.25 Mhz, clocked by clka).
I know from reg1 to rege, I can do like this:
set_multicycle_path -from reg1 -to reg2 -end -setup 4
set_multicycle_path -from reg1 -to reg2 -end -hold 3
But I do not know what multicycle I should set for path from reg2 to reg3, and from reg3 to reg4, could anybody help me? Thanks very much in advance.
    rbugalho, thanks very much for the nice answer.
    But I do not understand why setup 3, hold 2.
    In my design,
    I simply my code in the attachement, I'm wondering how should I set multicycle to reg2 to reg3, because different bit of reg2 is enabled by different clock_enable_counter.
    Should I set constraint like this?
    from ret2[0] to reg3[0], setup is 3, hold is 2, then
    from ret2[1] to reg3[1], setup is2, hold is 1,
    from ret2[2] to reg3[2], setup is 1, hold is 0, as default.
    from ret2[3] to reg3[3], setup is 4, hold is 3
    or I should set
    from ret2[0] to reg3[0], setup is 7, hold is 6, then
    from ret2[1] to reg3[1], setup is 6, hold is 5,
    from ret2[2] to reg3[2], setup is 5, hold is 4
    Which one is correct?
    Also from reg3 to reg4, and reg4 to reg5, can I set multicycle for those path, reg4and reg5 are clocked by 100MHz, but the original data (from reg3) would change every 4 clock cycles, perhaps it is possible to set multicycle to these paths?
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity rx_tapering_core is
    port (
    clk_4x : in std_logic; --(100MHz)
    reset : in std_logic;
    clock_enable_counter : in unsigned(1 downto 0);--(downscale data rate to 25MHz)
    clock_downsampler_en_counter : in unsigned(1 downto 0);--(downscale data rate to 6.25MHz)
    data_in : in std_logic_vector(3 downto 0);
    end entity rx_tapering_core;
    architecture rtl of rx_tapering_core is
    signal reg1 : std_logic(3 downto 0);
    signal reg2 : std_logic(3 downto 0);
    signal reg3 : std_logic(3 downto 0);
    signal reg4 : std_logic(3 downto 0);
    signal reg5 : std_logic(3 downto 0);
    signal reg6 : std_logic(3 downto 0);
    begin
    p_rx_tapering : process (clk_4x, reset)
    variable mult_res : signed(20 downto 0);
    begin
    if (reset = '1') then
    reg1 <= (others=>'0');
    reg2 <= (others=>'0');
    reg3 <= (others=>'0');
    reg4 <= (others=>'0');
    reg5 <= (others=>'0');
    reg6 <= (others=>'0');
    elsif rising_edge (clk_4x) then
    reg1 <= data_in;
    case clock_enable_counter is
    when "00" =>
    reg2(0) <= reg1(0);
    when "01" =>
    reg2(1) <= reg1(1);
    when "10" =>
    reg2(2) <= reg1(2);
    when others =>
    reg2(3) <= reg1(3);
    end case;
    --Multiplexer that provides 8 channels as input to multipliers
    when "00" =>
    data_mux_out <= data_in_d1(95 downto 0);
    when "01" =>
    data_mux_out <= data_in_d1(191 downto 96);
    when "10" =>
    data_mux_out <= data_in_d1(287 downto 192);
    when others =>
    data_mux_out <= data_in_d1(383 downto 288);
    end case;
    if clock_enable_counter = 3 then
    reg3 <= reg2;
    end if;
    reg4 <= reg3;
    reg5 <= reg4;
    if (clock_enable_counter = 3 and clock_downsampler_en_counter = 0) then
    reg6 <= reg5;
    end if;
    end if;
    end process p_rx_tapering;
    end architecture rtl;
    It's setup 3, because the path has 3 cycles to work with.
    Hold is 2. In this application, the hold multiplier is always N-1.
    Hei, I have a further question here:
    If reg2 is enabled when clock_enable_counter=0, while reg3 is enabled when clock_enable_counter=3, this means reg2 is 3 clock cycles earlier than reg3, what correct multicycles should be set now? I'm thinking setup 7, hold 3, is it correct? Could anybody tell me? Any help is appreciated!!!
    A setup multi-cycle exception of N means that the path always has, at least, N cycles to propagate the signal.
    So, you need to figure out how many cycles each path has, in the worse case scenario.
    If all you have are the enables then
    - reg1 to reg2 should not have a multi-cycle exception, since reg1's output may change just 1 clock before reg2 captures.
    - reg2 to reg3 should have a multi-cycle exception of 4 (3 for hold), because you're guaranteeing that reg2's output changes 4 cycles before reg3 captures, every time.
    - reg3 to reg4 again should have a multi-cycle exception of 4 (3 for hold) because, again, reg3's output may change only 4 cycles before.
    The -start and -end options don't have effect, since the start and end are in the same clock.
    sorry, should "start" instead of "end".
    set_multicycle_path -from reg1 -to reg2 -start -setup 4
    set_multicycle_path -from reg1 -to reg2 -start -hold 3
