14 years agoHow to set multicycle for this design?
In my design, all clocks are clka (100 MHz), but clock enables are used to make registers change at 25 MHz or 6.25 MHz. The signal path is reg1(clka,100MHz)->reg2(enable to 25 MHz, clocked by cl...
14 years agorbugalho, thanks very much for the nice answer.
But I do not understand why setup 3, hold 2. In my design, I simply my code in the attachement, I'm wondering how should I set multicycle to reg2 to reg3, because different bit of reg2 is enabled by different clock_enable_counter. Should I set constraint like this? from ret2[0] to reg3[0], setup is 3, hold is 2, then from ret2[1] to reg3[1], setup is2, hold is 1, from ret2[2] to reg3[2], setup is 1, hold is 0, as default. from ret2[3] to reg3[3], setup is 4, hold is 3 or I should set from ret2[0] to reg3[0], setup is 7, hold is 6, then from ret2[1] to reg3[1], setup is 6, hold is 5, from ret2[2] to reg3[2], setup is 5, hold is 4 from ret2[3] to reg3[3], setup is 4, hold is 3 Which one is correct? Also from reg3 to reg4, and reg4 to reg5, can I set multicycle for those path, reg4and reg5 are clocked by 100MHz, but the original data (from reg3) would change every 4 clock cycles, perhaps it is possible to set multicycle to these paths? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity rx_tapering_core is port ( clk_4x : in std_logic; --(100MHz) reset : in std_logic; clock_enable_counter : in unsigned(1 downto 0);--(downscale data rate to 25MHz) clock_downsampler_en_counter : in unsigned(1 downto 0);--(downscale data rate to 6.25MHz) data_in : in std_logic_vector(3 downto 0); ); end entity rx_tapering_core; architecture rtl of rx_tapering_core is signal reg1 : std_logic(3 downto 0); signal reg2 : std_logic(3 downto 0); signal reg3 : std_logic(3 downto 0); signal reg4 : std_logic(3 downto 0); signal reg5 : std_logic(3 downto 0); signal reg6 : std_logic(3 downto 0); begin p_rx_tapering : process (clk_4x, reset) variable mult_res : signed(20 downto 0); begin if (reset = '1') then reg1 <= (others=>'0'); reg2 <= (others=>'0'); reg3 <= (others=>'0'); reg4 <= (others=>'0'); reg5 <= (others=>'0'); reg6 <= (others=>'0'); elsif rising_edge (clk_4x) then reg1 <= data_in; case clock_enable_counter is when "00" => reg2(0) <= reg1(0); when "01" => reg2(1) <= reg1(1); when "10" => reg2(2) <= reg1(2); when others => reg2(3) <= reg1(3); end case; --Multiplexer that provides 8 channels as input to multipliers case clock_enable_counter is when "00" => data_mux_out <= data_in_d1(95 downto 0); when "01" => data_mux_out <= data_in_d1(191 downto 96); when "10" => data_mux_out <= data_in_d1(287 downto 192); when others => data_mux_out <= data_in_d1(383 downto 288); end case; if clock_enable_counter = 3 then reg3 <= reg2; end if; reg4 <= reg3; reg5 <= reg4; if (clock_enable_counter = 3 and clock_downsampler_en_counter = 0) then reg6 <= reg5; end if; end if; end process p_rx_tapering; end architecture rtl;
