14 years agoHow to set multicycle for this design?
In my design, all clocks are clka (100 MHz), but clock enables are used to make registers change at 25 MHz or 6.25 MHz. The signal path is reg1(clka,100MHz)->reg2(enable to 25 MHz, clocked by cl...
14 years agoIt's setup 3, because the path has 3 cycles to work with.
Hold is 2. In this application, the hold multiplier is always N-1.
