How to program a Cyclone III from Windows 11
I've recently upgraded my PC to Windows 11.
The only available 'Quartus II web edition' versions that I see in the Intel website are '13.1' and '13.0sp1', but both are failing to program my FPGA.
Is there any method that can allow me to program my Cyclone III from Windows 11?
I am completely blocked by this..
- KennyT_altera
As we do not receive any response from you on the previous question that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- KennyT_altera
Do you have further update on this? If no, we shall close this thread.
- KennyT_altera
Sure, we will open till next week.
- KennyT_altera
Do you have further question? If no, we shall close this thread.
Just in case you want to install the old version of Quartus 13.1. You may need to refer to the readme file for the supported OS:
System Requirements
Operating system support
* Windows 7 (64 and 32 bit)
* Windows XP SP2 (64 and 32 bit)
* Windows XP Pro X64 Edition
* Windows Server 2008 R2 (64 bit)
* Windows 8 (64 bit)
* Red Hat Enterprise Linux 6 (64 bit)
* Red Hat Enterprise Linux 5 (64 and 32 bit)
- EladArmon
Thanks, I will try this and update.
- EladArmon
- FvM
as stated, use a recent Quartus Programmer version, e.g. Intel Quartus Prime Programmer 24.1std.0.1077.
It comes with Windows 11 compatible USB Blaster driver and still supports all Cyclone devices and even older CPLDs like MAX3000.P.S., here's the link
- EladArmon
Hello FvM,
I am not generating program files, I'm only using quartus to program my FPGA (Cyclone III ) with existing files.
The problem is that the new Quartus version does not support this FPGA generation.
Do you know if there is an older Quartus version that supports both Cyclone III and Windows 11?
If so- how can I get it?
- FvM
apparently you did not try to use a recent Quartus Programmer version to send your existing configuration files to Cyclone III as suggested. Please give it a try.
- FvM
I read your post so that you succeeded in running Quartus 13 on Windows 11, can generate programming files but fail to download it with Quartus Programmer under Windows 11. If so, you can use a recent Quartus Programmer version. If the problem is different, please clarify.
