15 years ago
How to fix Quartus II Error 10031 and 10032
hi all,,
i have 2 problem with my verilog hdl coding.
when i ran in quartus ii, it show:-
1. Error (10031): Net "sig_speed[15]" at pro_dec6.v(13) is already driven by input port "initial_speed[15]", and cannot be driven by another signal
2. Error (10032): "initial_speed[15]" was declared at pro_dec6.v(5)
i also attach my verilog hdl.
thanks.
    No, what I mean is that you're doing a conceptual error.
    Only 1 process can drive one signal.
    that mean I need to do difference reg for both value..?
    ps: Sorry,,, I'm beginner in verilog hdl
    thanks Darkwave and Thormodo
    The problem is exactly what have been told you by previous poster.
    You're saying in code 2 different thing in different "process".
    You're saying 2 different thing and compiler of course do not know what you want:
    1) when reset then out speed = fixed value, else set it at initial speed.
    always @(reset or initial_speed)
    begin
    if (reset == 1'b0)
    out_speed = 16'b0000000000000000;
    else
    sig_speed = initial_speed; <- THAT'S FIRST ASSIGNMENT
    end
    2) In the following code you're saying a different thing
    always @ (clk or reset)
    begin
    if (reset == 1'b0)
    begin
    end
    else
    begin
    if (sig_speed == ref_speed)
    begin
    out_speed <= sig_speed; //out_speed <= initial_speed
    end
    else if (sig_speed < ref_speed)
    begin
    out_speed <= sig_speed; //sig_speed = 16'b0000000000000000;
    end
    else
    sig_speed <= sig_speed - 1; <- THAT'S THE SECOND ASSIGNMENT
    end
    end
    If you think of what you're implement, code in part 1 is a ASYNCRONOUS MULTIPLEXER in which the reset signal is the selector.
    THe 2 input of this mux are :
    1- Fixed value = 16'b0000000000000000;
    2- the signal initial_speed
    There is no space for the counter you're instanciating in the second part of your code.
    I suppose that what you want to write is different and maybe is only the second part of your code or maybe it's initial_speed that you want to be decremented..
    Well it is what it says.
    You are giving sig_speed[15] values from 2 different ports/signals.
    Somewhere in your code you have (this is VHDL code):
    something like this: sig_speed[15] <= example[15];
    And somewhere else (maybe in a parallel proces) you have sig_speed[15]<=initial_speed[15];
    Also your code isn't attached.
