Hi I would like to ask a questions about measure BSC package outline dimension.
100-Pin (TQFP) package have 14mm BSC dimension for size D1 and E1. After measure this dimension I have 13.82-13.84mm.
Package with dimension D1/E1 13.82mm conform specification for 100-Pin (TQFP)?
If I measure other BSC dimension for other package, how do I know measured size conform to the package specification or not, if BSC dimension do not have tolerance?
Your prompt reply would be appreciated.
- NurAiman_M_Intel
We are very sorry that we can't help that much but by following JEDEC standard, BSC has no tolerance.
According to our KDB, BSC means basic spacing between centers which has no tolerance. Apologize for the inconveniences.
KDB: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07152011_585.html
Aim
- NurAiman_M_Intel
Hi Andrey,
I just got this from internal team. BSC does not have tolerance. All our POD is following JEDEC specification. For this OPN, we follow JEDEC spec, MS-026- D variance AED. Intel's representative has sent you some information through private message. Please take a look.
Aim
- ALahn1
Hi.
Private message don't answer on me question.
Can you answer the question? If I measure BSC dimension for package (D1,E1=13.82mm), how do I know measured size conform to the package specification or not, if BSC dimension do not have tolerance?
D1,E1=14mm BSC
- ALahn1
Part number EP1C3T100C6N package https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/pkgds.pdf#page=67-68
This question about how to conform specification for all Intel FPGA package with BSC dimension, if BSC dimension do not have tolerance? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/pkgds.pdf
- NurAiman_M_Intel
We apologize for the delay in response as we are still investigate this matter. In the mean time, kindly provide the target device OPN for us to investigate more into this.
Thank you.
- NurAiman_M_Intel
Thank you for contacting Intel Community.
Please allow me some time to check this with our internal team. Appreciate much on your patience. Thank you.
Aim
