13 years agoHelp with CIC decimation filter
I wrote a Verilog code for a CIC decimation filter. I relied on a code written in the book 'digital signal processing with FPGA' . Here is the code: // cic decimation filter : R=64, M=1, N=3 module cicdecim64 (x_in,y_out,clk,reset); input clk,reset; input [7:0] x_in; output [7:0] y_out; parameter hold=0, sample=1; reg state; //sample or hold states reg [5:0] count; //count till 63 starting from 0 reg [7:0] x; //input wire [23:0] sx; //sign extended input reg [23:0] i0; //Integrator output section 0 reg [18:0] i1; //output section 1 under the consideration of Haugenauer's pruning reg [13:0] i2; reg [11:0] i2d1, c1, c0; // Integrator+COMB 0 reg [10:0] c1d1, c2; reg [9:0] c2d1, c3; always @(negedge clk) begin : FSM // finite state machine case (state) hold : begin if (count<63) // setting states for downsampling state <= hold; else state <=sample; end default: state <= hold; endcase end assign sx={{16{x[7]}},x_in}; // Integrator always @(posedge clk)begin if(reset) begin i0 <= 24'd0; i1 <= 19'd0; i2 <= 14'd0; end begin: I x <= x_in; i0 <= i0+sx; i1 <= i1+i0[23:7]; i2 <= i2+i1[18:5]; case (state) //downsample sample : begin c0 <= i2[13:1]; count <= 0; //reset counter once a sample has been fetched end default : count <= count+1; endcase end end // COMB always @(posedge clk) begin: COMB i2d1 <= c0; c1 <= c0-i2d1; c1d1 <= c1[11:1]; c2 <= c1[11:1]-c1d1; c2d1 <= c2[10:1]; c3 <= c2[10:1]-c2d1; end assign y_out=c3[9:2]; endmodule To test it, I wrote the following test bench: `timescale 1ns/1ps module test; reg clk,reset; wire [7:0] x; wire [7:0] y; assign x=8'd0; cicdecim64 cic (x,y,clk,reset); initial begin clk<=1'b0; reset <= 1'b0;# 3 reset=~reset;# 6 reset=~reset; end always# 4 clk=~clk; endmodule However, the simulation in modelsim shows the status of i0 changes to x at the first positive edge of the clock. Can anyone help me solve this problem? Thanks in advance
