Global Clock & Regional clock inputs in Agilex M FPGA
- 1 month ago
Based on the F-tile architecture and the SyncE operation.
1. Is SyncE clock recovery supported only on the FGT PMAs in Quad-2 and Quad-3?
Yes. The SyncE section says the recovered clock from the FGT PMA can be driven to dedicated clock output pins, and that each F-Tile has only two such outputs: FGT Quads 2 and 3. The architecture guide further says one RX CDR clock output must come from Quad 2 and the other from Quad 3.2. Is it not possible to recover the SyncE clock from transceivers in Quad-0 and Quad-1?
Correct for the dedicated SyncE recovered-clock output path. Public docs say the “Enable dedicated CDR clock output” option is available only for Ports 8–15, which map to FGT Quads 2 and 3, not Quads 0 and 1.3. Is SyncE clock recovery supported on FHT PMAs, or only FGT PMAs?
Based on the public F-Tile docs, it is only documented for FGT PMAs. The Ethernet SyncE chapter and the architecture chapter both describe FGT RX CDR clock output; the FHT clocking chapter describes FHT reference-clock inputs/common PLLs, not a corresponding SyncE recovered-clock output path.4. Which F-Tile transceiver types and quads support SyncE clock recovery?
- Supported for SyncE recovered-clock output: FGT, Quad 2 and Quad 3 only.
- Not supported for that output path: FGT Quad 0/1 and FHT PMAs.
I have a question regarding SyncE clock recovery in the Agilex M F-Tile transceivers.
1. Is SyncE clock recovery supported only on the FGT PMAs in Quad-2 and Quad-3 (the eight FGT transceiver channels)?
2. Is it not possible to recover the SyncE clock from the transceivers in Quad-0 and Quad-1 ?
3. Is SyncE clock recovery supported on the FHT PMAs in the F-Tile, or is it limited to the FGT PMAs?
Could you please clarify which F-Tile transceiver types and quads support SyncE clock recovery?
Thulasi
Dear Customer,
I'm glad that your issue is resolved. I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
