13 years agoGeneral questions about memories, configuration and FPGA systems.
I have done some research on the forum about the topic, but i have still some questions and want to verify and sum up everything. In my questions about system configuration i will refer to Cyclone III device family. 1. Some memories questions: 1a. Regarding SRAM memory for NIOS II code. I have seen people using two chips with 16 buses in parallel giving 32 bit bus. I haven't verified that, but is NIOS II using 32 bit instructions ? So it would be most efficent to use it like that. What about using only one chip ? Does it mean that NIOS would have to read the memory two times - so the code could be executed slower ? Also on this forum couple of people suggested for that not using A0 of the SRAM chip address. I was looking for SRAM chips on digikey with 32 bit data bus already - they are quite expensive. That's why it is better to use two 16 bit chips? 1.b. Is external SRAM memory with 10ns access time really much slower that for example internal on-chip sram with 100 MHz clock? 1c. Regarding FLASH memory. There are two main types of flash NANDs and NORs. As farest i know NAND have to be read/written in a page manner, while NORs can be accessed directly at desired address. Is it always better to use NORs with FPGA? Or is there a purpose for using NANDs? 1d. What about the main difference between SRAM and DRAM ICs. I know that: - SRAM usually has 6 transistors, and DRAM is one MOSFET + capacitor - so it's cheaper. - SRAM doesn't have to be constantly refreshed so it consumes less power. - And last thing that - please correct me if i'm wrong: SRAMs are faster, that's why they used as a cache memory, but ultimately DRAM synchronous clock, bursts allow for higher bandwidth ? 1e.Is with those other memories the same consideration about NIOS 32 bit bus and instructions? 2. System configuration. I have found out that EPCS configuration memories are quite expensive, that's why people usually don't use them, right ? Let's stick for a while with that memory anyway. 2a. I have read Cyclone III documentation regarding configuration. Active Serial is used with EPCS chips. I read the remote configuration part, and it seems that i can store as many configuration files in the epcs as i want. If the time comes i can using NIOS or my custom logic to reconfigure FPGA with a different code, configuration. The documentation suggested that the address for the memory configuration to start with is at the beginning of the EPCS. "When used with configuration memory, remote update mode allows an application configuration to start at any flash sector boundary." Is that correct ? 2b. In the same documentation there was also smth about that configuration memory can mean not only EPCS device but also parallel flash memory. Does it mean that for example instead of using expensive EPCS i could use cheaper NOR flash or what kind of flash ? and that i could have the same functionality, with remote configuration etc. using Active Serial? Ok just right now i have found here http://www.altera.com/support/devices/configuration/cfg-compare.html that it can be used, and it's called AP. And that it needs CFI flash. Any traps here? 2c. Can i in the same CFI Flash memory hold both more conifguration files and the code for NIOS II ? There are some NIos commands like: sof2flash, elf2flash, nios2-configure-sof,nios2-flash-programmer. Using those commands i can put everything that i want in that flash in different address space? It simply needs the pinout for FLASH and it knows how to use it? I can use for the connection FPGA GPIO? 2.d In case of having nios code in the same FLASH, i should simply give NIOS the addres of the beginning of the code for it in FLASH as a Reset Vector. 2.e. I haven't found that out - how is the code then copied to run from SRAM (for faster execution) - Because i can assume that it could be run directly from that flash. 2.f. Before i started to write this post i was thinking about using some microprocessor to program the FPGA using PS or FPP. I wanted to use some FLASH memory to store all different configurations for the FPGA, and mircoprocessor would simply read the FLASH and program the FPGA. I could use UART, USB or any different protocol i can come up with to upgrade for example the FPGA configuration automatically. However FPGA can receive data, reprogram the CFI Flash and reconfigure itself. So correct me if i'm wrong but there is really no need for external uC? ////////////////////////////////// Thanks for any answers to my questions, please address them by points and feel free to write some other stuff that i should consider, read documentation etc. best regards, madness18 Replies
The byte enables are there so you can have interfaces that are 16 or 32 bit wide and still retain the ability to address individual bytes.
NIOS has a 32 bit wide master interface. When it executes an 8 bit store instruction, it will automatically set the correct byte enables, along with the target address. If you only have an 8 bit or 16 bit wide memory bus, the memory controller shall also have an 8 or 16 bit wide slave interface. In this case, the Avalon fabric will make the adaptation between NIOS' 32 bit interface and the memory controller's 8 or 16 bit interface and everything will work correctly. What dsl was trying to convey is that the fabric will handle the conversion in less than 100% efficient manner. - Altera_Forum
--- Quote Start --- What dsl was trying to convey is that the fabric will handle the conversion in less than 100% efficient manner. --- Quote End --- Hi, thanks rbugalho for the anwser, will it take for the NIOS 2 clock cycles instead of 1 to read the 32 bits from 16 bit memory, or there is something else also to the effiicency loss? best Madness - Altera_Forum
Yes, a 32 bit read/write from a 16 bit memory will take 2 cycles. That's pretty much a given.
But even if the instruction only wants to read 8 or 16 bits, NIOS will perform read 32 bits, using two 16 bit accesses to the memory controller. And even if the instruction only wants to write 8 or 16 bits, there'll be two 16 bit accesses to the memory controller, with the byte enables being used to only write the intended address. That's the extra inefficiency. - Altera_Forum
The 16bit read will take an extra cycle (I think it is only 1, but it might be more - I avoid the bus width adapters if possible).
The nios cpu always stalls while doing an avalon cycle, the minimum delay is 2 clocks - so the instruction takes 3 clocks + any 'late result' stalls if the value read is used in the following 2 instructions. Reads from off-chip memory will be significantly slower (writes can be 'posted' and complete in later clocks). The Nios cpu itself doesn't have an option to 'post' Avalon writes. Accesses to tightly coupled data memory do not stall - except for a single clock stall for a write immediately following a read to the same tightly coupled memory block. - Altera_Forum
--- Quote Start --- Hi, 2. System configuration. I have found out that EPCS configuration memories are quite expensive, that's why people usually don't use them, right ? Let's stick for a while with that memory anyway. --- Quote End --- EPCS is not the only devices you can use; people substitute with "generic" serial flash devices like M25 family from ST. This blog summarizes, but is badly out of date cost-wise: http://fpgaforum.blogspot.com/2006/03/any-replacement-for-altera-epcs_19.html - Altera_Forum
--- Quote Start --- EPCS is not the only devices you can use; people substitute with "generic" serial flash devices like M25 family from ST. This blog summarizes, but is badly out of date cost-wise: http://fpgaforum.blogspot.com/2006/03/any-replacement-for-altera-epcs_19.html --- Quote End --- Hi Ted, That really makes sense. Yea the differece is quite big for EPCS16 and equivalent generic ST device (~14$ to ~1$). Thanks for the TIP ! best, madness - Altera_Forum
Hi Ted,
I have bought M25P16 and replaced EPCS16 with it and hell yeaa that works great. It's really substituting ~14 $ chip with ~1 $ one ! (digikey prices for one part). For EPCS64 and M25P64 the ratio is even greater - 32,5 $ compared to 3 $. That really gives quite big memory range for lots of configurations with altera remote update. I scoped the data clock of the memory when configuring the cyclone II, it was about 12,5 MHz. I wasn't able to find any info about speeding that clock for EPCS devices. Memory itself says that it's max. clock is 75 MHz. The EPC (enhanced) chip was reffered to have variable data clock. Don't really know the difference between EPC and EPCS devices. There are also EPCQ (quad SPI) devices. I have installed the newest Quartus II 12 lately and they were there. As farest i know they weren't available in older version of Quartus. There is a big chance that Altera used here also 'generic' quad SPI flash as their EPCQ, so one could also substitute that. best regards, madness
