13 years agoGeneral questions about memories, configuration and FPGA systems.
Hi, I have done some research on the forum about the topic, but i have still some questions and want to verify and sum up everything. In my questions about system configuration i will refer to ...
13 years ago --- Quote Start --- Hi, 2. System configuration. I have found out that EPCS configuration memories are quite expensive, that's why people usually don't use them, right ? Let's stick for a while with that memory anyway. --- Quote End --- EPCS is not the only devices you can use; people substitute with "generic" serial flash devices like M25 family from ST. This blog summarizes, but is badly out of date cost-wise: http://fpgaforum.blogspot.com/2006/03/any-replacement-for-altera-epcs_19.html
