13 years agoGeneral questions about memories, configuration and FPGA systems.
Hi, I have done some research on the forum about the topic, but i have still some questions and want to verify and sum up everything. In my questions about system configuration i will refer to ...
13 years agoYes, a 32 bit read/write from a 16 bit memory will take 2 cycles. That's pretty much a given.
But even if the instruction only wants to read 8 or 16 bits, NIOS will perform read 32 bits, using two 16 bit accesses to the memory controller. And even if the instruction only wants to write 8 or 16 bits, there'll be two 16 bit accesses to the memory controller, with the byte enables being used to only write the intended address. That's the extra inefficiency.
