16 years ago
Functional simulation vs Timing
I'm trying to plan an entity that recieves 2 6 bits words and decides if there are 3 or more different bits between those two words. If there are 3 or more bits that differs - the output turns to '1'.
I simulated the device in "Functional" mode and it did exactly what I thought it should do, but in timing mode simulation - it simply don't turn c to '1' at all.
Can someone please assist ?
here is the code:
Library ieee;
Use ieee.std_logic_1164.ALL;
use IEEE.std_logic_unsigned.all;
-- This entity detects if there are more then 3 changes
-- between 2 6bits inputs.
Entity change3 is
port (
-- inputs
async_reset : in std_logic;
clock : in std_logic;
a,b : in std_logic_vector(5 downto 0);
-- output
c : buffer std_logic);
end change3;
Architecture rtl of change3 is
begin
process (clock,async_reset)
variable x: std_logic_vector (2 downto 0) :="000";
begin
if (async_reset='1') then
c <='0';
x:="000";
elsif (clock'event and clock='1') then
x:=x+(a(0) xor b(0));
x:=x+(a(1) xor b(1));
x:=x+(a(2) xor b(2));
x:=x+(a(3) xor b(3));
x:=x+(a(4) xor b(4));
x:=x+(a(5) xor b(5));
end if;
if (x>"010") then c<='1'; -- there are at least 3 different bits
else c<='0';
end if;
--end if;
end process;
end rtl;
    i would also use signals for x.
    i dumped the code into Quartus, it doesn't optimize C out.
    dont use buffer type on a port map. No one uses them. Only use in or out (or inout only for top level ports).
    Use internal signals for storage instead.
    A potential problem I see is the assignment to C. because you have it outside of the clock its unlikely to behave properly. Keep all assingments in a clocked process inside the clocked part. This may also be why x does nothing - you're evaluating it outside of the clock - the synthsiser may have just thrown it away.
    Its best to keep to the standard templates.
    my mistake, x does infer a register.
    you should still check the timing report.
    if RTL simulation doesn't match gate level, you should make sure you've applied timing constraints to the design, then check your timing report. if you meet a longer period than the clock you're using in the timing simulation, the timing simulation results won't match the expected (RTL simulation) results.
    i don't think any registers will be inferred from your snippet, the code looks all combinatorial. is this what you expected?
