16 years agoFunctional simulation vs Timing
Hi, I'm trying to plan an entity that recieves 2 6 bits words and decides if there are 3 or more different bits between those two words. If there are 3 or more bits that differs - the output turns...
16 years agodont use buffer type on a port map. No one uses them. Only use in or out (or inout only for top level ports).
Use internal signals for storage instead. A potential problem I see is the assignment to C. because you have it outside of the clock its unlikely to behave properly. Keep all assingments in a clocked process inside the clocked part. This may also be why x does nothing - you're evaluating it outside of the clock - the synthsiser may have just thrown it away. Its best to keep to the standard templates.
