14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello
Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using the d2xx drivers sending exactly 512 bytes. the problem is when the fpga receives these 512 bytes and places them into a ram block module i am using, every time i send the 512 bytes it seams to read in 2 empty bytes first then reads in the correct 512 offsetting every thing by 2 bytes. then the next frame i send every thing is offset by 4 bytes then 6 and so on my code is very simple it has 2 buffers that are 3072 bytes (im only using 512 at the moment) it fills one then once that is full it swaps to the next one and fills that one. another bit of code is reading the none filling buffer and cycling the data to a dot matrix display (this part of the design is ok and can be ignored) below is the timing diagram for the 245 FIFI http://img580.imageshack.us/img580/5303/ft2232htiming.jpg i have attached my code. all dot matrix display update code can be ignored. the problem lies in the FIFO section. apart from these extra 2 bytes every frame (causing the buffer to be offset by 2 bytes every frame) it seams to behave correctly. CLK = 50mhz fifo_clk = 60mhz from FT2232H im not sure if its a timing fault or a fault in my state machine. i have attached my verilog file any help would be much appreciated or just to be pointed in the right direction :) its so close to working just this one little problem!15 Replies
Thank you very much for your reply.
I have a bad problem with FT232H which is very similar to FT2232H, but only 1 channel instead of 2. I have a data loss every 510 bit (tested on Win7 and Win8.1) and more in other cases. In sw I use this code with C# .NET library (v1.0.14.0) to read data Pseudocode:
*Data loss even with SetFlowControl(FTD2XX_NET.FTDI.FT_FLOW_CONTROL.FT_FLOW_RTS_CTS, 0, 0); I have tried to change buffer size (1024 in pseudocode) with other values. If buffer size is 1 no errors, in other case I have a lot of errors (about 0.016% data loss with buffer = 1024 bytes) Timing of FT232H are: http://imagizer.imageshack.us/v2/xq90/13/7cmg.png In VHDL I have this simple code:OpenBySerialNumber("FTXE2X2D"); SetBitMode(0xFF, FTD2XX_NET.FTDI.FT_BIT_MODES.FT_BIT_MODE_RESET); Thread.Sleep(10); SetBitMode(0xFF, FTD2XX_NET.FTDI.FT_BIT_MODES.FT_BIT_MODE_SYNC_FIFO); Purge(FTD2XX_NET.FTDI.FT_PURGE.FT_PURGE_RX) --Cycle Read(dataBuffer, 1024, ref numBytesRead); --End cycle Close();
That is a simply counter that continuously count up to 255 and so send 0,1,2..,254,255,0,1,2...,254,255 to pc and in SDC file I have set these constraints:library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity ft232h_tx is port ( FT_CLK : in std_logic; -- 60 MHz FT232H clock nTXE : in std_logic; -- Can TX nRXF : in std_logic; -- Can RX nRD : out std_logic; -- Read nSIWU : out std_logic; -- Send Immediate / WakeUp nOE : out std_logic; -- Output enable nWR : out std_logic; -- FIFO Buffer Write Enable ADBUS : out std_logic_vector(7 downto 0) -- Bidirectional FIFO data ); end entity; architecture rtl of ft232h_tx is signal counter : unsigned (7 downto 0) := "00000000"; begin -- don't read nOE <= '1'; nSIWU <= '1'; nRD <= '1'; process(FT_CLK, nTXE) variable state : std_logic := '0'; begin if (rising_edge(FT_CLK)) then if(nTXE = '0') then if(state = '1') then nWR <= '0'; -- last data not valid if nTXE goes LOW ADBUS <= std_logic_vector(counter); counter <= counter + 1; end if; state := '1'; else nWR <= '1'; state := '0'; end if; end if; end process; end rtl;
With signaltap I have take this screenshot: http://imagizer.imageshack.us/v2/xq90/30/e0pc.png (https://imageshack.com/i/0ue0pcp) But I can not find the error.. :(create_clock -name "FT_CLK" -period 16.67ns set_input_delay -clock { FT_CLK } -min 9ns nTXE set_input_delay -clock { FT_CLK } -max 0ns nTXE set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns }] set_output_delay -max -clock "FT_CLK" 7.500ns set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns }] set_output_delay -min -clock "FT_CLK" 0ns - Altera_Forum
Hello
Its been a while seen i placed with this stuff hehe, I ended up going with a STM32F04 micro instead of the ftdi/fpga Here is my code, hopefully if helps you out :) I am sending data the opposite direction, from the pc to the fpga. .c
fpgaFT_SetBitMode(ftHandle, 0xff, 0); Sleep(10); FT_SetBitMode(ftHandle, 0xff, 0x40); FT_SetLatencyTimer(ftHandle, 16); FT_SetUSBParameters(ftHandle,0x10000, 0x10000); FT_SetFlowControl(ftHandle, FT_FLOW_RTS_CTS, 0x0, 0x0); FT_Purge(ftHandle, FT_PURGE_RX); Sleep(10);
The fpga side of things a little bit more complex that you might need it as im checking the first three bytes in my packet to keep every thing in sync, if they are wrong it will discard the packet, you can chop this bit of code out if you want. It was for basic error checking and frame sync. The above code is just the logic for reading in the bytes from the ftdi, give me a shout if you want the full source. It is sort of mixed in with the full project though hehe.// ***************************** // FT2232H Synchronous 245 FIFO // ***************************** always @(posedge fifo_clk) begin case(fifo_state) 0: begin // wait for rxf to go low (byte available) if(rxf==0) begin oe=0; fifo_cnt=0; fifo_state=1; end end 1: begin rd = 0; fifo_state=2; end 2: begin // keep reading data untill rxf goes high if(rxf==1) begin rd = 1; oe = 1; fifo_state=0; end else begin // check frame preamble bytes if(preamble_state<3) begin wr_addr = 0; if(preamble==data_in) preamble_state=preamble_state+1; else preamble_state=0; end else if(preamble_state==3) begin // command byte (unused) preamble_state=4; end else begin // frame data bytes wr_addr = wr_addr + 1; // read in 2048 bytes (full frame) if(wr_addr == 2048) begin wr_addr=0; preamble_state = 0; // swap to next buffer buf_ready=!buf_ready; end end end end endcase end - Altera_Forum
So USB data can be corrupted by design by FT232H and we have to implement a CRC check over it?
Its usually ok but in my project i was streaming video frames at a very high fps and if some thing went wrong (very rare) It would screw up the image alignment, So in my case a needed to put in the simple frame header checking just to make sure I new where I was in case there was a little rare glitch.
Im sure you will not need this for sending some data from the fpga to the pc occasionally. - Altera_Forum
With great FTDI support I have solved problem TXE signal can go HIGH on falling edge of clock and so it must not be checked only on rising edge.
Working code:
Thanks to alllibrary ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity ft232h_tx is port ( FT_CLK : in std_logic; -- 60 MHz FT232H clock nTXE : in std_logic; -- Can TX nRXF : in std_logic; -- Can RX nRD : out std_logic; -- Read nSIWU : out std_logic; -- Send Immediate / WakeUp nOE : out std_logic; -- Output enable nWR : buffer std_logic; -- FIFO Buffer Write Enable ADBUS : out std_logic_vector(7 downto 0) -- Bidirectional FIFO data ); end entity; architecture rtl of ft232h_tx is signal counter : unsigned (7 downto 0) := "00000000"; signal state : std_logic := '0'; begin -- don't read nOE <= '1'; nSIWU <= '1'; nRD <= '1'; process(FT_CLK, nTXE) begin if (rising_edge(FT_CLK)) then if(nTXE = '0') then if(state = '1') then --nWR <= '0'; ADBUS <= std_logic_vector(counter); counter <= counter + 1; end if; state <= '1'; else --nWR <= '1'; state <= '0'; end if; end if; end process; nWR <= '1' when nTXE = '1' else '0' when (nTXE ='0' and state = '1'); end rtl;
