14 years agoFSM problem
Heyy I'm trying to make a video game in vhdl on de0 board and I need help about the following FSM. No error or warning. Does anyone notice a mistake??
thankss.type XY_REG_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_REG_TYPE is array (0 to 3,0 to 3) of std_logic;
type XY_NEXT_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_NEXT_TYPE is array (0 to 3,0 to 3) of std_logic;
type STATE_TYPE is (count,zero,left,down,right);
signal m : integer range 0 to 9;
signal n : integer range 0 to 19;
signal c,d : integer range 0 to 3;
signal ab_reg : AB_REG_TYPE;
signal xy_reg : XY_REG_TYPE;
signal ab_next : AB_NEXT_TYPE;
signal xy_next : XY_NEXT_TYPE;
signal state_reg, state_next : STATE_TYPE;
signal T_reg, T_next : integer range 0 to 10;
begin
FSM1: process (clk, reset, n, m, c ,d)
begin
if reset = '1' then
xy_reg(n,m) <= '0';
T_reg <= 0;
state_reg <= zero;
elsif clk'event and clk = '1' then
xy_reg(n,m) <= xy_next(n,m);
T_reg <= T_next;
state_reg <= state_next;
end if;
end process FSM1;
FSM2: process (SW(1), BUTTON, xy_reg, ab_reg, state_reg, T_reg, T_next, m, n, c ,d)
begin
xy_next(n,m) <= xy_reg(n,m);
T_next <= T_reg;
state_next <= state_reg;
case state_reg is
when count =>
if EndOfField = '1' then
T_next <= T_reg + 1;
if T_reg = 10 and SW(1) = '1' then
state_next <= zero;
else
state_next <= count;
end if;
end if;
when zero =>
if BUTTON = "111" then
if xy_reg(n+1,m) = '0' then
xy_next(n,m) <= xy_reg(n+1,m);
T_next <= 0;
else
T_next <= 0;
end if;
elsif BUTTON = "101" then
state_next <= down;
elsif BUTTON = "110" then
state_next <= right;
elsif BUTTON = "011" then
state_next <= left;
end if;
when down =>
T_next <= 0;
else
T_next <= 0;
end if;
when right =>
if xy_reg(n,m+1) = '0' then
xy_next(n,m) <= xy_reg(n,m+1);
T_next <= 0;
else
T_next <= 0;
end if;
when left =>
if m >= 1 then
if xy_reg(n,m-1) = '0' then
xy_next(n,m) <= xy_reg(n,m-1);
T_next <= 0;
else
T_next <= 0;
end if;
else
T_next <= 0;
end if;
end case;
end process FSM2;
