15 years agoFSM problem
Heyy I'm trying to make a video game in vhdl on de0 board and I need help about the following FSM. No error or warning. Does anyone notice a mistake?? thankss. type XY_REG_TYPE is array (0 ...
15 years agoSorry for late reply and thank you for your replies. After some tests I found problem and rewrite the code but this time I got some errors.
Error (10028): Can't resolve multiple constant drivers for net "xy_reg[1][1]" at VGA.vhd(255) Error (10029): Constant driver at VGA.vhd(241) The problem is not in state machine's cases at this time but I dont minimise the code anyway. When I erase the line underlined below, It kinda works but not enough. I know your ideas will be very helpful.type XY_REG_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_REG_TYPE is array (0 to 3,0 to 3) of std_logic;
type XY_NEXT_TYPE is array (0 to 19,0 to 9) of std_logic;
type AB_NEXT_TYPE is array (0 to 3,0 to 3) of std_logic;
type STATE_TYPE is (count,zero,left,down,right);
signal m : integer range 0 to 9;
signal n : integer range 0 to 19;
signal c,d : integer range 0 to 3;
signal ab_reg : AB_REG_TYPE;
signal xy_reg : XY_REG_TYPE;
signal ab_next : AB_NEXT_TYPE;
signal xy_next : XY_NEXT_TYPE;
signal state_reg, state_next : STATE_TYPE;
signal T_reg, T_next : integer range 0 to 10;
begin
TimeDelay : process (clk)
variable cnt : integer range 0 to 10 := 0;
begin
if clk'event and clk = '1' then
if EndOfField = '1' then
if cnt = 10 then
Delay <= '1';
cnt := 0;
else
Delay <= '0';
cnt := cnt + 1;
end if;
end if;
end if;
end process TimeDelay;
FSM1 : process (clk, reset)
begin
if reset = '1' then
state_reg <= count;
elsif clk'event and clk = '1' then
for n in 0 to 19 loop
for m in 0 to 9 loop
if xy_reg(n,m) = '1' then
state_reg <= state_next;
xy_reg(n,m) <= xy_next(n,m);
end if;
end loop;
end loop;
end if;
end process FSM1;
FSM2 : process (SW(1), BUTTON, Delay, xy_reg(n,m), state_reg)
begin
state_next <= state_reg;
xy_next(n,m) <= xy_reg(n,m);
case state_reg is
when count =>
if Delay = '1' and SW(1) = '1' then
state_next <= zero;
else
state_next <= count;
end if;
when zero =>
if BUTTON = "111" then
if n <= 18 then
if xy_reg(n+1,m) = '0' then
xy_next(n+1,m) <= xy_reg(n,m);
else
end if;
end if;
elsif BUTTON = "101" then
state_next <= down;
elsif BUTTON = "110" then
state_next <= right;
elsif BUTTON = "011" then
state_next <= left;
end if;
when down =>
if n <= 18 then
else
end if;
end if;
when right =>
if m <= 8 then
if xy_reg(n,m+1) = '0' then
xy_next(n,m+1) <= xy_reg(n,m);
else
end if;
end if;
when left =>
if m >= 1 and n <= 18 then
if xy_reg(n,m-1) = '0' then
xy_next(n,m-1) <= xy_reg(n,m);
else
end if;
end if;
end case;
end if;
end loop;
end loop;
end process FSM2;
Game: process (clk)
begin
xy_reg(1,1) <= '1';
end if;
end process Game;
