FPGA-to-HPS bridge, too slow?
Hi, my co-worker is using the Cyclone V with the embedded ARM cores. I often stop by his cube and ask him his opinion of the SoC. His biggest complaint is the FPGA-to-HPS bridge which he says is a big bottleneck. He admits that there may be some other knobs available to increase the throughput and make data transfers more deterministic but he hasn't found the knob. I thought to post this question and see the responses. I assume that when the Stratix 10 is released there wouldn't be such a bottleneck but I may be wrong. I'm still undecided about the embedded cores and am curious what applications it is best suited for. Can these cores, either on the Cyclone V or Stratix 10, compete with the multi-core DSPs from TI such as the TMS320C6678. All of my designs I have used a high-performance FPGA and a high-performance DSP. I'm waiting to see how things turn out before putting an SoC on my next design. I admit it is very exciting! Please let me know you comments. Thanks, joe
100 Mhz? so slow? how about the clock of the memory that you are using?
Hi, to answer the question. We had a FOR loop running on the HPS and it toggled a bit in a register on the FPGA side. There was no delay in the FOR loop, the executed as fast as it could. We tide the register bit to a test point where we could look at it on an oscope. We measured a 50% duty cycle square wave but the frequency was something near 16Mhz. The HPS clock was 100Mhz. Remember, that I did not work on this design, I'm only a by-stander relaying information. My main goal with this post is to get feedback from the community with their experiences with the bridge and how fast can one write to a register on the FPGA side from the HPS side. Hope this helps and if anyone has comments, please send them.
this is one of the area i never thought before, i think i need to take a look with my project files.
Do You use altera macros for read/write to this virtual adresses? (alt_read_word, alt_write_word) This macros have casts to volatile pointers which tells compiler that memory caching should be skipped. This is not the same as just dereferencing standard pointers.
My memory map call looks like this, might be flags are different: void * vbase = mmap(NULL,map_size, (PROT_READ | PROT_WRITE), (MAP_SHARED),mem_fd,(unsigned int)adress & ~(unsigned int)map_mask); - Altera_Forum
oh. i am using a map in Linux, then access via the virtual address. Using interrupts as well
OK, I also use Linux. I've not measured latency yet. My test runs for 10 seconds and I get very reproducable bandwidth for each run. How do You write to the bridge? Is it MM Interface and You do a mmap in Linux? Then read/write to virtual adress? Do You use interrupts?
I'm using a Linux OS only ,in order to have a priority with the thread running for data processing.
Do You have Linux running or do You have bare-metal? According to tech docu the LW-bridge should have less latency than normal bridges. Did You tried both?
There is some small lag during peak transfer, but those mainly is due to the post data manipulation on the Arm core area, as my manipulation task priority is quite high.
No, but my traffic on lw-bridge is low: writing about four hundred DMA descriptors per second, each 20 bytes or so. Is Your congestion permanent? or is it a small lag?
