10 years agoFPGA-to-HPS bridge, too slow?
Hi, my co-worker is using the Cyclone V with the embedded ARM cores. I often stop by his cube and ask him his opinion of the SoC. His biggest complaint is the FPGA-to-HPS bridge which he says is a bi...
10 years agoHi, I use only lightweight bridge for configuring DMAs per Avalon-MM interface. I transfer data from FPGA directly to DDRAM without going to CPU. The CPU only waits for transfer to complete.
If You add "Cyclone V Hard processor system" You can define that You want to have "FPGA-to-HPS SD-RAM interface" available so You get port f2h_sdram0_data in hps component. Then I connect DMAs mm_write/mm_read ports to f2h_sdram0_data.
