Amir21's avatar
Amir21
4 years ago
FPGA MAX10 in "User-Mode" indication
I'm using DPRs in MAX10-FPGA and init their memory through .hex files.
In order to verify when the FPGA initialization process done,
I'm trying to use the "INIT_DONE" output pin for inidication to release the FPGA external reset signal.
Apparently, I can't find it and enable this pin (INIT_DONE) in Quartus 20.1.1 in the output options.
I'll be glad to know what other possibilities I can use in order to get inidcation for the FPGA enters into "User-Mode" ?
Thanks!
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    • Amir21's avatar
      Amir21
      I actually meant to the IP Component -
      RAM: 2-Port
      Aizik Amos.
  • Hi,
    Since INIT_DONE is not mention in the User guide, then there is not INIT_DONE can be check.
    The other option is, you can check the status of the I/O pin as per your design. In user mode, the user I/O pins will then function as specified by your design.
    Aiman
    • Amir21's avatar
      Amir21
      Sounds like a good idea, I will definitely try it.
      In addition,
      Any idea until when the FPGA reset should remain valid, when we use the DPR IP in my design?
      Aizik Amos.
    • Amir21's avatar
      Amir21
      That's exactly the issue..
      The 'CONF_DONE' indication is not enough, I need to know when the initialization process has done..
      I tried to find out from the spec how can I use the MAX10 'INIT_DONE' through the Quartus tool, with no success..
  • sstrell's avatar
    sstrell
    I think you're looking for CONF_DONE, not INIT_DONE, which you have enabled there.
    • Amir21's avatar
      Amir21
      Since in my design I'm using DPRs which initialized from HEX files, I need to know when the initialization process done.
      I'm looking for any valid indication from the FPGA to indicate when it entered into 'USER-MODE' (initialization process finished).
