Amir21
4 years agoFPGA MAX10 in "User-Mode" indication
I'm using DPRs in MAX10-FPGA and init their memory through .hex files.
In order to verify when the FPGA initialization process done,
I'm trying to use the "INIT_DONE" output pin for inidica...
NurAiman_M_Intel
4 years agoHi,
SStrell is correct. You can refer to CONF_DONE status to see if the FPGA has enter user mode.
Please refer to the MAX 10 UG as given by sstrell and you can also refer to MAX pin connection guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Aiman
- Amir214 years ago
That's exactly the issue..
The 'CONF_DONE' indication is not enough, I need to know when the initialization process has done..
I tried to find out from the spec how can I use the MAX10 'INIT_DONE' through the Quartus tool, with no success..
