Amir21
4 years agoFPGA MAX10 in "User-Mode" indication
I'm using DPRs in MAX10-FPGA and init their memory through .hex files.
In order to verify when the FPGA initialization process done,
I'm trying to use the "INIT_DONE" output pin for inidica...
NurAiman_M_Intel
4 years agoHi,
Since INIT_DONE is not mention in the User guide, then there is not INIT_DONE can be check.
The other option is, you can check the status of the I/O pin as per your design. In user mode, the user I/O pins will then function as specified by your design.
Aiman
- Amir214 years ago
Sounds like a good idea, I will definitely try it.
In addition,
Any idea until when the FPGA reset should remain valid, when we use the DPR IP in my design?
Aizik Amos.
