Amir21
4 years agoFPGA MAX10 in "User-Mode" indication
I'm using DPRs in MAX10-FPGA and init their memory through .hex files.
In order to verify when the FPGA initialization process done,
I'm trying to use the "INIT_DONE" output pin for inidica...
NurAiman_M_Intel
4 years agoHi,
Since INIT_DONE is not mention in the User guide, then there is not INIT_DONE can be check.
The other option is, you can check the status of the I/O pin as per your design. In user mode, the user I/O pins will then function as specified by your design.
Aiman
Amir21
4 years agoHi,
Sounds like a good idea, I will definitely try it.
In addition,
Any idea until when the FPGA reset should remain valid, when we use the DPR IP in my design?
Aizik Amos.
In addition,
Aizik Amos.
