alparodi's avatar
alparodi
3 years ago
FPGA JTAG Circuit for Cyclone II
Hi. I am developing a Cyclone II - EP2C20AF256I8N FPGA schematic using the EPCS16SI8N memory. I wanted to know if the following schematic is correct to program it through USB BLASTER ALTERA CPLD. If I have any mistake, could you please correct me?
Is it necessary to put the two headers to record it also by AS?
  • Hello,
    the configuration interface is implemented correctly. You don't need a second AS header, flash will be programmed through JTAG by using JTAG indirect configuration.
  • Thank you FvM for sharing the solution.
  • FvM's avatar
    FvM
