alparodi
3 years agoFPGA JTAG Circuit for Cyclone II
Hi. I am developing a Cyclone II - EP2C20AF256I8N FPGA schematic using the EPCS16SI8N memory. I wanted to know if the following schematic is correct to program it through USB BLASTER ALTERA CPLD. If ...
- 3 years agoHello,
the configuration interface is implemented correctly. You don't need a second AS header, flash will be programmed through JTAG by using JTAG indirect configuration.
NurAiman_M_Intel
3 years agoThank you FvM for sharing the solution.
