13 years ago
FPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme?
I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interface. I've read from the PCIe specification that the minimum time between the PC's power rails being stable and the PCIe PERST# signal being deactivated is T_PVPERL = 100 ms (acitvating and deactivating PERST# causes a reset of the PCIe interface and causes PCIe lanes to initialise). You get another 100 ms from receiving the PERST# signal before the sequence starts, so that's a total of 200 ms. The PCIe specification only states a minimum time between power being stable and sending the PERST# signal, so you could get a few seconds before you have to be ready, but I don't know if I can rely on this.
Using the active serial configuration scheme would take me 1.225 s, so it seems I have to use a different scheme, such as FPP. Altera recommend this in their application note AN529:
“For Cyclone IV GX devices to meet the PCIe 100 ms wake-up time requirement, you
must use PS configuration mode for the EP4CGX15, EP4CGX22, and EP4CGX30
(except for F484 package) devices and FPP configuration mode for the EP4CGX30
(only for F484 package), EP4CGX50, EP4CGX75, EP4CGX110, and EP4CGX150
devices.”
FPP is a pain because you need another chip to manage the configuration process and this chip (MAX II or a microprocessor) needs its own software.
So my question is: has anyone got the PCIe interface to work reliably while their configuration takes over 200 ms? I'd also like to hear if you haven't! Thanks.
