17 years ago
Flash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt:
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00404040:
verified
No CFI table found at address 0x00200000
Leaving target processor paused
Can anyone help me in sorting out this issue?
THS!
Handsome
    Hello handsome, WP/ACC could be left floating, because there is a pull up resitor inside.
    You have set the base address to 0x00000000, correct ?
    Set t(setup), t(hold) and t(wait) to 200ns, we can increase the speed later!
    Have you connected pin BYTE to VCC or GND ??? It's really important to know that!
    Hi,Maestro666,as your advice,i typed the commond----nios2-flash-programmer --base=0x00000000 --debug
    It still shows that:No CFI table found at address 0x00000000.
    I locked the base_address of flash,make it to 0x00000000.
    BTW,I made pin--WP/ACC and NC(13-pin) floating.
    t(setup)=50ns;t(wait)=40ns;t(hold)=35ns;
    Waiting for your reply!
    Thanks!
    hi,i connected EA[21..0]with A[20..0]of flash----AM29LV320,and the pin-EA0 is floating!but it still dosen't work!what can i do!it's so annoying!
    Have you selected "Byte" or "Word" mode for your flash ??? Type following command in nios2 command console:
    nios2-flash-programmer --base=0x00200000 --debug
    If you see the cfi table, then you can be shure that your flash is correct connected.
    Try running the nios2-flash-programmer.exe from the nios2 command console with the --debug option and look at the CFI table. The most likely cause of this problem is the address lines are off by one i.e. the SOPC A0 bit should go to the A(-1) bit of the Flash.
