17 years agoFlash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pau...
17 years agoHello handsome, WP/ACC could be left floating, because there is a pull up resitor inside.
You have set the base address to 0x00000000, correct ? Set t(setup), t(hold) and t(wait) to 200ns, we can increase the speed later! Have you connected pin BYTE to VCC or GND ??? It's really important to know that!
