17 years agoFlash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pau...
17 years agoHave you selected "Byte" or "Word" mode for your flash ??? Type following command in nios2 command console:
nios2-flash-programmer --base=0x00200000 --debug If you see the cfi table, then you can be shure that your flash is correct connected.
