17 years agoFlash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pau...
17 years agoTry running the nios2-flash-programmer.exe from the nios2 command console with the --debug option and look at the CFI table. The most likely cause of this problem is the address lines are off by one i.e. the SOPC A0 bit should go to the A(-1) bit of the Flash.
