16 years ago
Flash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt:
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00404040:
verified
No CFI table found at address 0x00200000
Leaving target processor paused
Can anyone help me in sorting out this issue?
THS!
Handsome
    Hi handsome, I hope R11 isn't soldered...
    You doesn't need to connect pin-13 and pin-15 !!!
    You wrote (and set address width to 22-bit), I think that isn't a good idea to give your processor a wrong information about your ram. Take a look at the attachment and try it...
    hello,maestro,i found the real problem.when the flash_oe is low level,its voltage is 1.5V,what's the reason?thanks!
    handsome
    Hello handsome, solder out R7 to R9 and try again...
    Let's see whether it works...
    I have solder out R8 and R9,Flash_ce is normal,but Flash_oe and Flash_ce is the same result(low voltage is about 1.5V,can't below it).But when i use these pins alone,its low voltage is normal(about 0.4V).I can't fingure out what's the real reason.Is it the reason of CFI core?
    hi,Maestro,I have a good news to tell u!It works normally now!The real reason is that:the pin-WE is not soldered very well!
    Thanks for your kindly help and best regards!
