16 years ago
Flash generated using sof2flash fails to configure fpga
Hi ,
I have Stratix IV development kit ,
I want to load Flash file converted using sof2flash utility.
when i use nios2-flash-programmer it works fine .
but it fails to configure FPGA from flash when i cycle power the board .
Anybody have idea ?
    Thanks Ton . Its better idea to make thread on NIOS forum .
    Hi Dipen,
    Although I also used the Stratix IV development kit, I didn't use NIOS on it. My last NIOS experience is from some years ago, so I'm afraid I can't help you with the kernel panic problem. Well, at least you've set one step. Maybe for the next one, it's better to make a thread in a NIOS forum. I will follow it with interest.
    Good luck, Ton
    when i run nios2-terminal, it shows like this ,
    linux/nios ii-mmu
    init_bootmem_node(?,0x105a2, 0x10000, 0x18000)
    free_bootmem(0x105a2000, 0x7a5e000)
    reserve_bootmem(0x105a2000, 0x1000)
    built 1 zonelists in zone order, mobility grouping on. total pages: 32512
    kernel command line:
    pid hash table entries: 512 (order: -1, 2048 bytes)
    dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    we have 98304 pages of ram
    memory available: 124140k/5767k ram, 0k/0k rom (2077k kernel code, 3690k data)
    hierarchical rcu implementation.
    nr_irqs:32
    calibrating delay loop... 74.75 bogomips (lpj=373760)
    mount-cache hash table entries: 512
    net: registered protocol family 16
    init_bsp(): registering device resources
    bio: create slab <bio-0> at 0
    ------------[ cut here ]------------
    warning: at /opt/dipen/nios2-linux/linux_source/linux-2.6/fs/sysfs/dir.c:451 sys
    fs_add_one+0xb0/0xe0()
    sysfs: cannot create duplicate filename '/class/net/lo/statistics/'
    modules linked in:
    stack from d7c16d94:
    d7c16dd8
    d0012548
    ffffffef
    d7c1e000
    d7c5fd74
    d0588db4
    d00125cc
    d0555b18
    d7c16dc0
    00000001
    d00c04f0
    d7c1e000
    d7c5fd74
    fffffff4
    d05890b4
    0000000e
    d0151a9c
    d0588f3c
    d7c4cdfc
    d0588d80
    00000000
    00000001
    d0152330
    00000000
    d01342e4
    d7c16e64
    d7c4ce04
    00000000
    00000000
    d0588dc0
    d7c4cc00
    d7c4cdfc
    call trace:
    [<d0197cf0>]
    [<d0188944>]
    [<d0188b3c>]
    [<d01830fc>]
    [<d01830fc>]
    [<d01832e8>]
    [<d018338c>]
    [<d0000210>]
    [<d00b0000>]
    [<d0002294>]
    [<d000e250>]
    [<d00021f8>]
    [<d0001074>]
    [<d0002288>]
    ---[ end trace 4eaa2a86a8e2da22 ]---
    kernel panic - not syncing: loopback: failed to register netdevice: -17
    I can not understand ..why this happen ?
    Thanks Ton,
    i successfully flashed .sof using that , actually i was using programmingmode=PS .
    But you are flashing the sof using factory default CFI flash map.
    when i tried to boot from software flash(elf2flash) it goes to Kernel Panic.
    sof2flash -------- as u shown
    nios2-flash-programmer --base=0x08000000 <yourfile>_hw.flash
    Up to this it works fine , now i am converting linux image,
    elf2flash --base=0x0a000000 --end=0x0bffffff --reset=0x0a820000
    --input=<yourfile>_sw.elf --output=<yourfile>_sw.flash
    --boot=path/boot_loader_cfi.srec
    nios2-flash-programmer --base=0x0a000000 <yourfile>_sw.flash
    now , i powercycle the board , it boots but comes kernel panic.
    And if i want to load my custom sof and linux image without the factory default settings , is it possible ?
    I used sof2flash with the following options:
    sof2flash --input=stratix_iv.sof --output=stratix_iv.flash --offset=0xC20000 --pfl --optionbit=0x18000 --programmingmode=FPP
    Success, Ton
    Thanks , but i am currently working with EDS 9.1 SP2 . Is there any PFL or optionbit issue ?
