16 years agoFlash generated using sof2flash fails to configure fpga
Hi , I have Stratix IV development kit , I want to load Flash file converted using sof2flash utility. when i use nios2-flash-programmer it works fine . but it fails to configure FPGA fro...
16 years agowhen i run nios2-terminal, it shows like this ,
linux/nios ii-mmuinit_bootmem_node(?,0x105a2, 0x10000, 0x18000)
free_bootmem(0x105a2000, 0x7a5e000)
reserve_bootmem(0x105a2000, 0x1000)
built 1 zonelists in zone order, mobility grouping on. total pages: 32512
kernel command line:
pid hash table entries: 512 (order: -1, 2048 bytes)
dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
we have 98304 pages of ram
memory available: 124140k/5767k ram, 0k/0k rom (2077k kernel code, 3690k data)
hierarchical rcu implementation.
nr_irqs:32
calibrating delay loop... 74.75 bogomips (lpj=373760)
mount-cache hash table entries: 512
net: registered protocol family 16
init_bsp(): registering device resources
bio: create slab <bio-0> at 0
------------[ cut here ]------------
warning: at /opt/dipen/nios2-linux/linux_source/linux-2.6/fs/sysfs/dir.c:451 sys
fs_add_one+0xb0/0xe0()
sysfs: cannot create duplicate filename '/class/net/lo/statistics/'
modules linked in:
stack from d7c16d94:
d7c16dd8
d0012548
ffffffef
d7c1e000
d7c5fd74
d0588db4
d00125cc
d0555b18
d7c16dc0
00000001
d00c04f0
d7c1e000
d7c5fd74
fffffff4
d05890b4
0000000e
d0151a9c
d0588f3c
d7c4cdfc
d0588d80
00000000
00000001
d0152330
00000000
d01342e4
d7c16e64
d7c4ce04
00000000
00000000
d0588dc0
d7c4cc00
d7c4cdfc
call trace:
[<d0197cf0>]
[<d0188944>]
[<d0188b3c>]
[<d01830fc>]
[<d01830fc>]
[<d01832e8>]
[<d018338c>]
[<d0000210>]
[<d00b0000>]
[<d0002294>]
[<d000e250>]
[<d00021f8>]
[<d0001074>]
[<d0002288>]
---[ end trace 4eaa2a86a8e2da22 ]---
kernel panic - not syncing: loopback: failed to register netdevice: -17 I can not understand ..why this happen ?
