16 years agoFlash generated using sof2flash fails to configure fpga
Hi , I have Stratix IV development kit , I want to load Flash file converted using sof2flash utility. when i use nios2-flash-programmer it works fine . but it fails to configure FPGA fro...
16 years agoHi Dipen,
Although I also used the Stratix IV development kit, I didn't use NIOS on it. My last NIOS experience is from some years ago, so I'm afraid I can't help you with the kernel panic problem. Well, at least you've set one step. Maybe for the next one, it's better to make a thread in a NIOS forum. I will follow it with interest. Good luck, Ton
