Sir, Hello!
I used the code you write to debug to the actual circuit not simulation, and found it
cannot produce word_clk clock signal, so I have written in verilog a divider circuit, to produce mclk and word_clk signal, and made ​​some changes to your program (Delete word_clk produce circuit ), and then debug, I find the
result of the conversion are all 0 (DATA [15 .. 0]).After all, it cannot work in actual circuit.I don't know why,Could you tell me?Have you ever used the AD7401 to apply a actual project such as a sampling circuit of voltage?
The following is a modified program of you:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity AD7401decimationfilter is
port(reset, mdata, clk20,word_clk: in std_logic;
DATA : out std_logic_vector(15 downto 0);
ads_clk : out std_logic);
end AD7401decimationfilter;
architecture RTL of AD7401decimationfilter is
signal CN2_D2,DN1_D,DN2_D,DN1,DN2,DN3 : std_logic_vector(24 downto 0);
signal CN1, CN2 : std_logic_vector(24 downto 0);
signal delta : std_logic_vector(24 downto 0);
--signal word_count : std_logic_vector(7 downto 0);
--signal word_clk : std_logic;
begin
ads_clk <= clk20;
p11:process(clk20, reset)
begin
if reset = '0' then
delta <= (others => '0');
elsif clk20'event and clk20 = '1' then
-- if mdata = '1' then
delta <= delta + 1;--mdata;
--end if;
end if;
end process p11;
p12:process(reset, clk20)
begin
if reset = '0' then
CN1 <= (others => '0');
CN2 <= (others => '0');
CN1 <= CN1 + delta ;
CN2 <= CN2 + CN1;
end if;
end process p12;
--DECIMATION STAGE (MCLKIN/WORD_CLK)
--process(clk20,reset)
--begin
-- if reset ='0' then
-- word_count <= "00000000";--(others => '0');
-- elsif clk20'event and clk20 = '0' then
-- if word_count="11111111" then
-- word_count<="00000001";
-- else word_count <= word_count + 1; -- word_count is an 8 bit reg for decimation 2^8= 256
-- end if;
-- end if;
--end process;
--process(word_count,reset)
--begin
--if reset = '0' then
-- word_clk <= '0';
-- oe<='0';
--else
-- word_clk <= word_count(7);
-- oe<=word_count(7);
--end if;
--end process;
p13:process(reset, word_clk)
begin
if reset = '0' then
CN2_D2 <= (others => '0');
DN1_D <= (others => '0');
DN2_D <= (others => '0');
DN1 <= (others => '0');
DN2 <= (others => '0');
DN3 <= (others => '0');
elsif word_clk'event and word_clk = '1' then
DN1 <= CN2 - CN2_D2;
DN2 <= DN1 - DN1_D;
DN3 <= DN2 - DN2_D;
CN2_D2 <= CN2;
DN1_D <= DN1;
DN2_D <= DN2;
end if;
end process p13;
--p14:process(word_clk,reset)
--begin
-- if reset = '0' then
-- DATA <= (others => '0');
-- elsif word_clk'event and word_clk = '1' then
-- DATA(15 downto 0) <= DN3(23 downto 8); -- extracting the Most Significant Bits MSB
-- end if;
--end process p14;
begin
if reset = '0' then
if word_clk = '1' then
if DN3(24) = '1' then
DATA(15 downto 0) <= (others => '1');
else
end if;
end if;
end if;
end process;
end RTL;
*i wrote it myself sub-frequency signal procedure as follows: module dividefrequency(sysclk,reset,mclk1,mclk2,word_clk);
input sysclk;
input reset;
output mclk1;
output mclk2;
output word_clk;
wire sysclk;
wire reset;
reg mclk1;
wire mclk2;
reg word_clk;
reg [31:0] div_count;
reg [7:0] word_count;
integer location;
integer info_file;
//wire [7:0] dec_rate;
//parameter rate=256;//280wen,256(12M);//70->1/2 i2c//116->1.4*16;
//parameter h_rate=64;
//assign dec_rate = 256 - rate;//ini value
assign mclk2=mclk1;
initial
begin
end
/*divide sysclk 50MHZ to 6.25MHZ*/
always @(posedge reset or negedge sysclk)
if(reset)
begin
div_count<=0;
end
else
begin
div_count<=div_count+1;
if(div_count==8)
div_count<=1'b1;
end
always @(div_count,mclk1)//mclk
begin
if(div_count<=4) mclk1<=1;
else if(div_count<=8) mclk1<=0;
end
always @ (negedge mclk1 or posedge reset)
begin
if (reset) word_count <= 0;
else if (word_count == 8'hFF) word_count <=1;// dec_rate+1;
end
always @ (word_count)
word_clk <= word_count[8];
begin
if(word_count<=64)//64)
word_clk<=1;
else if(word_count<=8'hff)//255)
word_clk<=0;
end
endmodule
sysclk is 50mhz,which is divided to 6.25mhz as mclk and 24.41khz as word_clk.
